RS2: First time replacing discs and pads myself..ever.
  • RS2ZuidAfrika
    Registered User
    • Jun 2012
    • 63
    • Home: South Africa Current: Palestine
    Hi all.
    I plan on replacing the discs and pads on my RS2 this weekend.
    Just the fronts. I collected my OEM discs from Porsche and I am using Ferodo pads.
    Do I need to bleed the system? It was done not even 2000km ago.
    I have never ever worked on brakes before, apart from repairing my ABS issues on my B5.
    If it seems too complicated i'll take it to a shop.
  • jade
    • Jan 2005
    • 1811
    Originally posted by RS2ZuidAfrika
    Hi all.
    Hi
    With RS2 brakes its good to remove the pad sliding plates at either end of the calipers and clean behind and replace or refit as they are prone to corrosion behind them which stops the pad from sliding freely
    The small hex bolts that hold these are a bitch to remove
    RS 2 580HP
