996 Brake Issues
  • gadget6970
    • Jan 2010
    • 87
    996 Brake Issues
    996 calipers on my s2 are getting hot under normal driving.Had to remove pads on drivers and clean up and relube about a month ago on route to our hols.it got so hot made steering wheel vibrate had to pull over and remove. luckly found some leather builders gloves at roadside so i could strip down without waiting hours to cool down.When first bought s2 a couple of years ago it had brake humming issues when driving and stopped when braking, every few weeks after trying various products to stop noise,silicone with copper in is doing the trick holding shims to pads and no humming.I have been running new disks and pads since october and for the 3rd time i,ve had this over heatng prob in the last few weeks on the drivers side and this time its both sides .i wonder if i need to file down more of the edge of the metal backing plate which the pads slides on in the caliper but if i over do it humming may come back to haunt me .
  • Rusty
    • 18953
    Could be bleeding issue or you need to get some anti rattle shims
    • gadget6970
      • Jan 2010
      • 87
      it is blood and tears at mo lol
      • Rusty
        • 18953
        Created a new thread for you
        The copper gasket does a good job of securing the anti rattle shims, so that's all good.
        When you took out the spring plate, was there much corrosion on it?
        Are all the pistons retracting OK?
        Another option is that the wheel bearings are getting old...
        • gadget6970
          • Jan 2010
          • 87
          Thanks for that squire Wheel bearings have done 20,000 still no play,there isnt a spring plate on mine its a bit like figure of 8 retaining spring. theres a slight bit of corrosion under the stainless brake pad slider plates.large pistons move easily but smaller ones take a bit of moving.ive got motul 600 brake fluid to put in and aquired a brake bomb
          • AndyP
            • 6049
            If they've got stainless pad slider plates, they're not 996 calipers. You got any pictures?
            • gadget6970
              • Jan 2010
              • 87
              calipers
              here some pics of my calipers
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                They're not 996 calipers.
                Does the brake pedal feel ok? Not long or anything?
                SS
                • gadget6970
                  • Jan 2010
                  • 87
                  pedal feels fine.Do you know what callipers they are bud ?
                  • AndyP
                    • 6049
                    They look like 'Big blacks' or Porsche 928.
                    • mcandmar
                      • Apr 2004
                      • 5118
                      Look like 993 calipers, common problem is corrosion under the stainless pad mounts which in turn wedges the pads in place.
                      91CQ20v - Gone to a new home
                      93UR-S4 - The Magic Carpet
                      94S2Bus - The Emerald Express
                      • gadget6970
                        • Jan 2010
                        • 87
                        I think that could be the problem ,i did try to undo allen bolt once but allen key started to slip so left it just wanted to clean up brake dust a bit more thoroughly but thats me being ott.Is it a good idea to remove slider plates to clean or is it going to cause more probs.allen bolts dont have much depth in them
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          i think you should strip them down and clean them up, check for corrosion and so on.
                          Don't use n allen key. Use a hammer to 'wake up' the bolts, then get a good sized breaker bar on them.
                          SS
                          • Rusty
                            • 18953
                            I originally posted that they might be 993s that had gone south but was told they were 996s...
                            Sell them on and buy some secondhand 996s, although that's not necessarily foolproof.
                            • AndyP
                              • 6049
                              If you're talking about the small allen bolts that hold the slider plates in place, the best way to get them out is to weld a new bolt to the top of them, had to do this a few times and it's never failed.
