Any interest in UrS4 rear brake adapters for 310x22 discs
Some partnumbers of the discs:
AUDI 4E0 615 601 A
AUDI 4E0 615 601 K
A.B.S. 17607
ATE 24.0122-0212.1
BOSCH 0 986 479 062
DELPHI BG3958
FTE BS7118
GIRLING 6042692
MEYLE 115 523 1124
MINTEX MDC1697
MINTEX MDC2063
NK 2047126
PAGID 54224
PAGID 54523
PILENGA V234
QUINTON HAZELL BDC5689
TEXTAR 92152300
TRISCAN 812029191
TRW DF4269
ZIMMERMANN 100.3311.00
BMW 740iA e38 - ProjectComment
What's caliper clearance like with the wheel now that you've moved the calliper out 15-20mm? Would some larger hat height discs not be better?
Edit: can't see much suitable in 22mm thick at that diameter
1994 ABY Coupe - Projekt AlpinweissComment
If you look at the stock discs on urs4/6, they are so deep in that you need binoculars to see them behind the wheels. I don't think 15-20mm gona be an issue.
1976 RD250E / 350LC cafe racerComment
Can you humour us and try a 16" Fuchs wheel over the prototype bracket and caliper? If it works without clearance issues, there will be lots of interest over here (Canada and the US of A).RS2'd 93 UrS4 5 spd sedan
I look't at he Phaeton calipers, but they can be hard to fit on UrS4. At least the hand brake cables fitts in wrong direction and there isn't much play in them.
BTW what is the piston size in the Phaeton calipers?Last edited by Thuppu; 20 July 2013, 07:21.
The handbrake pulls sideways like the URs4/6 calipers:
The mounting bolt spacing is much wider though, but still only a bracket required to fit them.
IIRC its a 43mm piston, I will check later. The caliper is much larger than the URs4/6 ones though
Imola B6 S4 AvantComment
