How bleed the brakes with ABS?
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    I changed brake lines and hoses,than put new brake fluid and bleed the brakes.Yesterday during test drive,when i brake the brake pedal is going too low and sometimes i heard a ABS . Its any differences to bleed the brakes with and without ABS?The car is cq20v.
    Thank you
    Audi Coupe Quattro 2.3 20V
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    you should start at the wheel the furthest away from the ABS. Then other rear side, front furthest, and then nearest.
    And best to go round 2-3 times to make sure.
    • Tom_
      • Oct 2007
      • 1301
      i do that,but its no good...
      • Henkjan
        • 1705
        how did you bleed? did you use a pressure source such as the ezbleed, or the old way using your foot on the pedal?
        • Tom_
          • Oct 2007
          • 1301
          i am using a foot on the pedal....
          • stocious
            • Jul 2012
            • 838
            just a thought , did you have your master cylinder removed whilst you were doing all the work ? and if so did you bleed it on a bench before fitting to the car.
            1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
            • Tom_
              • Oct 2007
              • 1301
              No master cylinder was fitted all the time.I only get out the brake fluid contanier to flush the rest of the fluid,what was there
                Then you need two people or one-way valves.
                • Tom_
                  • Oct 2007
                  • 1301
                  yes,i did it with my mate
                  • Christophski
                    • 3632
                    push the peddle, open the nipple, push peddle to floor slowly, do nipple up, pump peddle 10 times, then repeat the process.
                    Repeat the process each time remembering to pump the peddle 10 times gently between each go. i have never found this to fail me or my brother who is a mechanic.
                      Originally posted by Christophski
                      push the peddle, open the nipple, push peddle to floor slowly, do nipple up, pump peddle 10 times, then repeat the process. Repeat the process each time remembering to pump the peddle 10 times gently between each go. i have never found this to fail me or my brother who is a mechanic.
                      Strongly suggest that "push peddle to floor" is TOO FAR. By doing so, you will push the piston and the seal past their normal area of action, past what might be a "lip" in the cylinder, potentionally damaging the seal, necessitating a rebuild or replacement. Better to limit travel by placing some block of wood on the foot board behind the peddle.
                      • Christophski
                        • 3632
                        Or do the above I have never done that but maybe I should
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          That's a really good idea, I'm going to do that from now on.
                          OP, I'd try pressure bleeding the system in the same order.
                          1990 B3 2.0 80 quattro.
                          1992 C4 2.8 Avant quattro
                          1994 MTM RS2.
                          1998 B5 TDI quattro Sport.
                          2000 B5 TQS.
                          • Fat Audi 80
                            • 10547
                            Never had a problem bleeding the an ezibleed pressure bleeding system. HTH
                            The Perfectionist
                              Originally posted by Avantus
                              you should start at the wheel the furthest away from the ABS. Then other rear side, front furthest, and then nearest. And best to go round 2-3 times to make sure.
                              And don't forget the clutch slave which uses the same fluid as the brakes. Do this last.
