How bleed the brakes with ABS?
and lets say i dont bleed the clutch slave, what then ? it was bled once after the engine swap, now i changed the front calipers, and have some strange issues at higher speeds
danlolasdad, nice diy bleeder
Guys, please, i change front brake lines,hoses (for Goodridge), discs , pads (Hawk hp+) and 4 piston brembo calipers (all in front). And bleed it with "one man push , second bleed " and when i get my car from the garage, i noticed that brake pedal goes too low when it starts braking and very easy...I expect that the brake power will be huge (as one member said and he have the same spec on audifans.net) Do you think, that it will be just badly bleede?Or brake master cylinder is too weak or maybe a brake bomb? I am so sad from it. Its on my Audi Coupe Quattro 20V
So resume (New brake lines front + rear)
Front 4 piston Brembos + 324mm discs + Hawk hp+ pads + Goodridge + EBC 307+ fluid
Rear Oem calipers + OEM discs + EBC yellow stuff + Goodridge + EBC 307+ fluidLast edited by Tom_; 9 August 2015, 13:05.Audi Coupe Quattro 2.3 20VComment
