The red flashing 'BRAKE' periodically comes up on the autocheck.
Is there any way to find out what triggers it? VAG Com?
Candidates are -
Anything else?
I believe that if it was a light, it would say brake light (I've put mine in English
This has been coming on and off since I swapped out the brake servo, although that could just be my brain playing tricks. Just want to know what to check.
Brakes work fine and the bomb is about 6 years old. I've got some new fluid but the stuff that's in there is about 18 months old and it's had many litres to flush it through over the years.
Candidates are -
- pas reservoir
- brake reservoir
- pressure sensor
Anything else?
)This has been coming on and off since I swapped out the brake servo, although that could just be my brain playing tricks. Just want to know what to check.
could be
Although it occasionally happens first thing and then goes off.
