After fitting my brembo calipers in there new coat of paint some fluid has run down the outside penetrating the paint and causing it to peal off grrrrr
DOT 5 is good cause it does not damage paint has anyone used this on a Audi S2
I have read that it does not provide the same lubrication as DOT 4 for the Abs pump
any help or advice gratefully accepted
cheers Jamie
cheers Jamie
