URGENT - safety issue - ABY nearly killed me
  • rj scotty
    replied
    Can we do a bit reverse engineering on that hose? find the route cause and all that 9 (other than Corry is a ****, which he evidently is)
  • s2driveruk
    replied
    Wow...close shave
  • rynaqui
    replied
    Originally posted by Fat Audi 80
    Unlucky Brian, glad to hear you are okay. Corey was a first class :Corey: !
    Is that why the :corey: is tagged as corey then?
    Glad all ended well in the end.
  • Fat Audi 80
    replied
  • spink
    replied
    Even some cars with split lines can end up in same predicament. 2wd c4s have an aluminium restrictor on each rear line which oxides and fails one immediately after the other.has happened to me and I think gt500s car (or his dads) amongst others. No fun at 70mph
    replied
    Originally posted by BrianSmith_S2
    ...The brake upgrade and uprated lines were fitted through Cory in lincoln.
    If this is Cory (Corey?) of quattronics fame, then it wasn't the ABY that tried to kill you, it was Corey.
    There are lots of braided lines that are good. Goodrich comes to mind. Actually OE rubber hoses can be used, even on big Brembo brakes.
  • A80Avant
    replied
    The diagonal circuits isn't something that could be done?
    Thank god you are ok.
  • BrianSmith_S2
    replied
    Originally posted by Error404
    Glad you and the car are ok! what brand were they?
    6 years ago i won a porsche brake upgrade at the annual forum billing meet, the kits great value for £5 worth of raffle tickets.
    The brake upgrade and uprated lines were fitted through Cory in lincoln. As far as i know the lines were custom made, so dont know the make of the lines. Just thought it was worth pointing out to people that have uprated systems to check their lines. I was shocked to find no brakes with just one brake line failing...shame the S2 doesnt run diagonal circuits like most other cars.
    replied
  • BrianSmith_S2
    started a topic URGENT - safety issue - ABY nearly killed me
    Went out for a drive today after ultrasonicly cleaning my injectors when i dabbed on the brakes and the the pedal went straight to the floor
    As you can see from the photo the stainless mesh brakeline failed big time and i lost all brakes. Most cars have spilt diagonal systems and apparantly not the S2 which is split front rear
    Anyone with such an upgraded line i suggest checking over at the next service for seeping and signs of early failure. Luckily i was driving along a mile long straight road...god knows the result if it happened on the track or going into a fast corner
    Brian
