Brake bomb
  • Brake bomb
    Can anybody explain exactly how it works and where is pressure sensor I've got warning light on dash brake and power steering levels are ok.could I bridge sensor for bomb pressure so i can rule out any others sensors putting light on thanks
    Most likely bomb which is not holding enough pressure hence the warning light. I changed mine and haven't seen the light since..about 4 months ago.
    Last bought mine from Pete at Quattro Corner
    1996 S2 ABY Silver
      How the tandem vane PS/PB pump works:
      http://forums.quattroworld.com/s4s6/msgs/38240.phtml
      How the pressure-assist power brake system works on a 20VT:
      http://forums.quattroworld.com/s4s6/msgs/25095.phtml
      Here is a more detailed look. The brake pressure warning switch is item 4:
        Hi could you give me the email address sand telephone number for Pete from Quattro corner...
          quattrocorner@btconnect.com
          1996 S2 ABY Silver
            I think the valve on the brake bomb may have gone on mine, can you get the valve the goes on it separately?
              How much are the bombs from Pete thanks. would anybody go for servo conversion or stay with standard system how much would I be looking to convert and how would I turn light off if I did conversion
