Brake bomb
  • smiler131177
    • Mar 2013
    • 45
    Brake bomb
    Can anybody explain exactly how it works and where is pressure sensor I've got warning light on dash brake and power steering levels are ok.could I bridge sensor for bomb pressure so i can rule out any others sensors putting light on thanks
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Most likely bomb which is not holding enough pressure hence the warning light. I changed mine and haven't seen the light since..about 4 months ago.
    Last bought mine from Pete at Quattro Corner
    1996 S2 ABY Silver
      How the tandem vane PS/PB pump works:
      How the pressure-assist power brake system works on a 20VT:
      Here is a more detailed look. The brake pressure warning switch is item 4:
      • theyagaraj
        • Feb 2010
        • 57
        Hi could you give me the email address sand telephone number for Pete from Quattro corner...
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          quattrocorner@btconnect.com
          1996 S2 ABY Silver
            I think the valve on the brake bomb may have gone on mine, can you get the valve the goes on it separately?
            • smiler131177
              • Mar 2013
              • 45
              How much are the bombs from Pete thanks. would anybody go for servo conversion or stay with standard system how much would I be looking to convert and how would I turn light off if I did conversion
