-89 coupe 4-bolt better brakes?
  • salama
    • Oct 2013
    • 2
    I bought -89 coupe turbo, no original S2. It has 4-bolts wheels. Is there ready bolt on BIGGER 4-bolt disk for 18"wheels? Or do i have to change 4-bolt to 5-bolt? Horsepower will be about 400 and i like drive also on track.
    These are the 4-bolt wheels that i found...
    Vanteet, renkaat, korjaamokoneet sekä sähköajoneuvot tukkuhinnoin vannetukku.fi verkkokaupasta.
    sorry bad english
  • Rusty
    • 18953
    Swap to 5 stud is going to be the best for secondhand parts.
    Only option I know of on 4 stud is to use Focus RS discs and upgrade the calipers.
    Of course, there's always the option of some custom bells for AP racing / Brembo etc. 2 piece discs and 4 or 6 pot calipers.
    • bazburn
      • Feb 2010
      • 583
      As Rusty says Focur Rs Mk1 discs ( need to open middle out a touch ) brackets from Bambridge on here with Boxster S calipers ( 4 pot monoblock ) and a bit of new brake pipe to join all together....
      Decent Calipers=£350 ish
      Brackets=£150 ish
      Discs=£150 ish
      Pipes=? depends on your pref....
      HTH
      • Kieron20V
        • Mar 2008
        • 1505
        As above, Ford Focus RS Mk1 Discs. Centres need boring out to match the hubs, and bolt holes enlarging.
        Then any calipers for that size of disc, easiest is porsche brembo stuff as adaptors are readily available.
        Cheapest, I bought 4 pot brembos off a BMW E38 728 £150 for the pair, and pads for £30. But then you have to figure out your own mounts.
        Discs are currently under £100 a pair for pagids from ECP.
        1994 URS4 Avant RS2+
        • sam80quattro
          • Oct 2006
          • 1496
          passat 312mm with discs redrilled to 4 stud. or passat 312mm discs (redrilled) boxster calipers. rs2 mounts machined down to bring the caliper outwards and Spacers to lift caliper upwards. that's what Im running on my 90
          • salama
            • Oct 2013
            • 2
            Thanks !!! So it´s possible after little bit of work. What about this kind of setup? Front Focus RS MK1 324mm discs with porsche 996 calibers and Back Focus ST170 300mm discs with audi S calibers.
            Which wheels would take 17" * 8 or 18" * 8 ?
            • bazburn
              • Feb 2010
              • 583
              My 17" Oz Superleggera's fit fine over the setup I mentioned above....
              • Tom_
                • Oct 2007
                • 1301
                • Country: Czech Republic
                bazburn: "need to open middle out a touch" ? Are u talking about enlarge the center hole in the focus rs brake disc?
                Audi Coupe Quattro 2.3 20V
                • Kieron20V
                  • Mar 2008
                  • 1505
                  Tom, yeah the focus discs have a smaller centre hole and need opeing to 68mm Kiev, and also the bolt holes need enlarging.
                  Sent from my HTC One X+ using Tapatalk
                  • Tom_
                    • Oct 2007
                    • 1301
                    Thanks lot. I am considering,that i used a focus RS discs + 4 pot Brembos from Tourag + brackets...
                    • GazzaG60
                      • 4133
                      on the 5 stud there is loads of clearance. not sure, but doubt theres as much space on the 4 stud. pretty sure my 16v has less clearance to rim than the 5 stud i have.
                      a mate just did his tt with brembos and the wheels wouldn't clear without spacers.
                      • bazburn
                        • Feb 2010
                        • 583
                        I am...
                        • Kieron20V
                          • Mar 2008
                          • 1505
                          I need approx 10mm spacers to clear the calipers when I mocked mine up.
                          • Tom_
                            • Oct 2007
                            • 1301
                            I think,that i do not need a spacers with the new wheels and new 324mm brakes...will se....
                            • Kieron20V
                              • Mar 2008
                              • 1505
                              Depends how much clearance you have behind the spokes on your wheels, mine hit the calipers. Can't remember offset of my wheels.
