Originally posted by Thuppu
View Post
School me on HP2 brakes (please)
Originally posted by K7ERG View PostMy hp2 s are different to the photos above. No springs
My calipers have 2 inner pads which are held in the pistons. The outer pads are held in by 2 torxs. I will at my brakes this week so will take some photos. There is also a difference on the carrier part if 314mm discs to 323mm. The mounting holes are in a different position.
1. What size is that Torx that holds the pads to the HP2 calipers? (I have them)
2. Did you ever take photos Craig? If so, did you post them and I missed them?
3. 314 x30 Rotors are not available in NAmerica. Could I get A8 323 x 30 rotors and get 4.5 mm milled off their edges to create 314 x 30 rotors?
Dave, check my thread, I stripped my front callipers and rebuilt them. Some pics on my thread.
http://www.s2forum.com/forum/showthread.php?p=892245
And on.
Sent from my Nexus 6P using Tapatalk1994 URS4 Avant RS2+
Those 323mm discs woud be ok to machine down to 314mm, but you would propably be able to order right discs from ebay.co.uk or ebay.de or maybe from your local autoparts store if you go with second hand parts, Zimmermann for example.
Originally posted by Kieron20V View PostDave, check my thread, I stripped my front callipers and rebuilt them. Some pics on my thread. http://www.s2forum.com/forum/showthread.php?p=892245 And on.RS2'd 93 UrS4 5 spd sedan
Originally posted by Thuppu View PostThose 323mm discs woud be ok to machine down to 314mm, but you would propably be able to order right discs from ebay.co.uk or ebay.de or maybe from your local autoparts store if you go with second hand parts, Zimmermann for example.
Originally posted by UrS4boy View PostI can buy 323 x30x for $87 each. A 314 x 30 rotor on eBay is between GBP 125 and GBP 140 ($202) each before shipping, making the 323 x 30 attractive in terms of both accessibility and price. Ignore the drilling in the second diagram.
Originally posted by UrS4boy View PostJust came back from checking out a shop that can literally chuck a new 323 x 30 rotor into a metal lathe and turn it down to 314 x 30. $10 a piece. No brainer.
"Nulla tenaci invia est via"
Originally posted by A1QSHIP View PostBe careful that the smaller diameter of the rotor face is sufficient for the brake pad to cover. You do not want the lower edge of the brake pad to overhang the swept pad area.RS2'd 93 UrS4 5 spd sedan
