Remove ABS --> ware brake lines on master cilinder.
  • V6quattro
    • Sep 2008
    • 949
    Maybe a stupid question but i removed the ABS system so now i need to make new lines.
    Does it matter ware i connect the front and rear brakes to the master cylinder?
    1360kg/600Whp Avant 0-200km/h 9sec
  • mrtat2k9
    • Jan 2009
    • 659
    rear brakes to front of cylinder and front brakes to the rear of the cylinder i found out the hard way under hard braking rears locked up and put us backwards over a roundabout. but since a put the rears on the front off the cylinder much better hope this helps
    • V6quattro
      • Sep 2008
      • 949
      Thanks mrtat2k9!
      I will also use a manual brake bias valve to prevent the rear brakes locked up.
      • mrtat2k9
        • Jan 2009
        • 659
        i dont have one and they only lock up when iv just about come to a stop.
        • V6quattro
          • Sep 2008
          • 949
          Good to know. I'm also planning to instal big Porsche rear brakes and hydro handbrake soon so that's way i have the manual valve.
          • mrtat2k9
            • Jan 2009
            • 659
            ok but im running 300 s4 rear brakes with the 996 front up grade
