Remove ABS --> ware brake lines on master cilinder.
Maybe a stupid question but i removed the ABS system so now i need to make new lines.
Does it matter ware i connect the front and rear brakes to the master cylinder?
rear brakes to front of cylinder and front brakes to the rear of the cylinder i found out the hard way under hard braking rears locked up and put us backwards over a roundabout. but since a put the rears on the front off the cylinder much better hope this helps
