330mm powervane rotors prorace 1 4 pot piston calipers
Originally posted by alg
My car has standard RS2 brake set up.
I am interested to know which porsche calipers will fit as direct exchange for present front ones.
I have searched and read many a thread however most cover bigger brake set ups.
I dont need recommendations that involve 'better' specs.
Just info such as 'porsche boxster 1996 front is direct exchange etc'
The plan is to go down this line in the future with a more modern caliper to avoid some of the well recognised issues with alloy 'corrosion' build up that occur.
I would reccomend qrsport brake solution caliper set ups 315mm or 330 powervane rotors an excellent braking soution excetional performance and sensibly priced will out brake most
kind regards
I would reccomend qrsport brake solution caliper set ups 315mm or 330 powervane rotors an excellent braking soution excetional performance and sensibly priced will out brake most www.compbrake.co.uk
kind regards
something i would like to clarify...you can only get the rear discs for the rs2 drilled(299x24)from audi alone?Porsche does not sell the same rotors with the offset that rs2 needs?Also since i am near in reaplcing the rear drilled rotors for my rs2,where can i find the replacements besides audi?
cheers
Vasilis
Thought someone might have come along with a definitive answer. In reply to your first post, not sure if the 322 mm Porsche disc comes normal/vented, or only cross drilled. My discs on the front are from Audi and are cross drilled.
On my previous RS2, I had the standard 304mm discs/calipers up front. These were also replaced and were not drilled.
This has probably confused matters more now
