Scrubbed the Benz brake project....
  • junkeravant
    • Jul 2012
    • 29
    Because a pair of excellent Porsche Cayenne brake calipers fell into my lap. The hard lines are missing off the caliper body. Can the front caliper hard brake line be used off the A4/B5 caliper on the Porsche one? They seem to be similar.... 3/16” , bubble flare, 10-1.0mm.
  • junkeravant
    • Jul 2012
    • 29
    Well here is what I intend to use...
    This will be used with a Porsche Cayenne caliper which seem to be cheaper to get than Boxster or 911 Calipers. The brackets are 5/8" thick 7075 T6 Aluminum. You would need 10G to even crack them...F1 cars do not exceed that much G-force.
    • BosnianS2
      • Apr 2005
      • 322
      • Home: Bosnia and Herzegovina Current: Germany
      I hope that you are not going to leave those screws like shown on pic . You bracket can be as strong as a mountaing, but if you cut off part of the screw head like that you are creating a weak link.
      I personally dont like your solution with screw.
      • martinjs
        • 3205
        Maybe 10g to crack when cold but a lot less when hot, 7075 not ideal, it's working temps you need to be thinking about, use 6082-T6.
        • martinjs
          • 3205
          Just noticed that bolt head, are you a member of team bodge?
          • junkeravant
            • Jul 2012
            • 29
            That was a preliminary set up to see if....
            things line up correctly. If you notice the hub wasn't even attached to anything...duh. As to 6082 T6 ..here in the US that stuff is not suggested. 7075 we have here must be tougher that the stuff you guys got there. Many race teams here swear by it and some of the tuning outfits here use it successfully while 6082 is ok, many here settle for 7075.
            • junkeravant
              • Jul 2012
              • 29
              Why I'm using 7075.
              and why 6082 IS NOT GOOD for what I'm doing...check the UK info.
                crack on then mate, literally
                • Doc_brown
                  • Aug 2013
                  • 35
                  its on wikipedia so its gotta be true
                  • martinjs
                    • 3205
                    I take it you haven't read all that second link?
                    "In general, of the two available alloys, 6082 may be the "default" choice for its lower cost and ease of forming. 7075 will be reserved for those applications in which its greater strength and toughness justify its higher cost, brittleness under extreme stress, and production challenges."
                    As I said it's working temps you need to be thinking about.
                    • martinjs
                      • 3205
                      Yeah it must be tougher. After all it's what that quality American tuning firm ECS use.
                      Here's a pic of one of their brackets that seems to have split in half.
                      Have fun.
                        You must have missed the other thread Martin
                        • mike74
                          • Apr 2014
                          • 615
                          I'm sure I've got some high temperature glue that would fix that bracket no probs!
                          IMO it's just not worth the risk of getting it wrong with brakes. If in any doubt, make it out of decent quality steel & make it chunky too
                          • mike74
                            • Apr 2014
                            • 615
                            Another thought to add to the mix, aluminium thermally expands at a different rate compared to steel. This might explain the broken bracket shown above...
