Piston size on 429/430 Porsche 4 pots
    Anyone know the piston sizes on the 996 Big Reds as fitted to the C4S & GT3
  • Takumi
    • Oct 2009
    • 120
    • Home: Lithuania Current: United States
    Hi Alex,
    996-351-429 & 996-351-430 GT2/GT3 C4 Turbo Front Calipers...
    Piston Sizes 38 & 44mm
    BLOG: http://quattro10vt.wordpress.com/
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Big reds?
      The Mitsubishi Evo V,VI,VII,VIII,IX brembos 4 pot calipers has 2x 42mm and 2x 46mm pistons.
      Works originally with 320x32 rotors and are far cheaper to buy second hand than the overpriced gt3 4pot big reds.
      • Thuppu
        • 4115
        Tomas, what are you still doing here? Go away ricer!
          Thanks for the info guys
          I did look at the Evo calipers but I'm not sure they can swallow as large a rotor?
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            Still got 2 Audis , 2x engines, and hundred parts stored
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              How large?
                Around 350mm?
                Also what size rotor annulus do they use? (The width of the contact patch on the rotor?)
                TBH I never see them go for much less than £300, which you can pick up GT3 calipers for too
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  Around 350mm?
                  I can ask in the MLR forum about disc thick and diameter options
                  But what everyone does is fitting very good quality 2 piece rotors from Performance Friction , good fluid , braided lines and very good pads for your requirements ( pagid , carbotech, PF ... ) and that's more than enough .
                  Or they goes to the 6 pot conversion with AP or Alcons... +2k£ ..
                  About calipers, I've seen bargains in the private part for sale forum...
                    Thanks Thomas. Yes this is my plan, floating two piece setup
                    I will get on MLR to have a look
                    • GazzaG60
                      • 4133
                      iirc evo discs have issues.
                      got gt2 6 pot for the little extra cost. saves doing it again
                        Yeah the GT2 6 pots are very nice and light, but they cost a fortune second hand and pads are also extortionate.
                        • _ShurikeN
                          • Mar 2010
                          • 733
                          • Country: Russian Federation
                          With such brake disc diameter why not to go Porsche Cayenne 6 pots? At ours they are often cheaper than RS2/EVO/Boxter/996 when second-hand.
                          S8 D2 345mm brembos would be my favorite option because of radial bracketing and second hand price much lower than porsches' brembos.
                            Alex you are better off going Porsche Cayenne 6 pots as they are more readily available. However I had the GT3 4 pots on my S2 and they are effin fantastic brakes!
