Big Brake conversion onto B7 A4
  • Monkeymagic
    • Mar 2012
    • 3419
    Caliper mocked up on S2
    s you can see there are some subtle differences. it does fit the disc perfectly. The pads are the same just a little longer. I reckon looking at the size of the carrier jim had fitted that there is plenty of room to make a carrier on the A4. I have a rare day to myself tomorrow so will offer them up to the 320 S4 discs on my A4 then make a visit to see Dave at BG... I actually reckon they would mate up to the S2 carriers fine but the offset is wrong for the A4.
      You are quite right mate they are the larger 4 pots
      If you are making custom brackets for them, I would definately use the 345mm S4 rotors, they are not expensive and you will make full use of the larger caliper
      • Monkeymagic
        • Mar 2012
        • 3419
        I'll have a look/think On it tomorrow when I can offer them up to the car.
        • Monkeymagic
          • Mar 2012
          • 3419
          A little update. With 320 the caliper was too close to the upright to fit a carrier. So it would require 345mm. Not a problem however the caliper fouls the wheel. I'd need a 15 mm spacer, that's not happening.
          plan b was looking at 4 pot options but the price was around 1/3 value of the car.
          plan c 2.0 tfsi calipers/ carriers with 320 x 30 s4 discs sorted for 250 quid. I believe they are the same as early b6 s4 so that's good enough for me. Better bite and better looking behind 18s oh and cheap and a simple bolt On then bleed, perfect!
            B6 S4 brakes are pretty good actually, I've not managed to smoke ours yet and tried pretty hard
            • Monkeymagic
              • Mar 2012
              • 3419
              I'm sure I'll be very happy with them and it's a cheap factory fit upgrade that is cheap to maintain on my daily.
              • Monkeymagic
                • Mar 2012
                • 3419
                S4/TFSI Brake upgrade fitted
                Here is the end result. If I get chance i may put a little silver paint on then but for me its a case of function over looks at this time.
                  Nice upgrade for the price too
                  • Gavin A
                    • Nov 2012
                    • 260
                    Does anyone know if I can fit B5 RS4 disks and callipers to a front drive B7?
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      yes you can. The mounting point centre to centre measurment on the upright is 146 mm same as B6/B7
                      • Human Joist
                        • Nov 2012
                        • 189
                        I ended up selling the callipers on after they were no good for Steve. The cayenne 18z are massume though
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          I hate it when people don't close a thread. I've replaced the rear discs and pads with New bosch ones plus a fluid chrange.
                          after just 30 miles it feels like hitting a wall when tapping the brakes. The pedal travel is just right and firm. Great upgrade!
