The Brake Component Weight Thread
  • A1QSHIP
    • Aug 2004
    • 975
    Rotor information
    Originally posted by Error404
    Cheers Chris, can you confirm what platform? I will add them to the list
    Sorry, Should be C6 chassis. I used the C6A6 rotor for the Cayenne calipers I am installing on my C4S6. More information here.
    Working on fitting the Cayennne rear calipers now.
    "Nulla tenaci invia est via"
      Thanks
      When you have some info on those Cayenne rears post it up
      • terrybullwon
        • Mar 2006
        • 8782
        James - do you have part numbers for your calipers & rotor for reference? (Not hat may folk will be choosing them I shouldn't think )
        Disc is
        CP5772-6072/6073
        Caliper
        RH XA6.61.22*
        LH XA6.61.21*
        Pad family 8087 Pagid
        Chef
          Nice one Chef
            • 12431
            I'll be replacing my AP discs in the new year so I'll try to remember to weigh the lot before I refit.
              That'd be great Greg. AP have the rotor data online, be great to get a measure of the calipers
              • Julian Iversen
                • Jul 2013
                • 84
                • Country: Denmark
                #22
                As far as I remember my Cayenne 18Z calipers is 6.5 kg
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #23
                  Empty without pads, pin and springs?
                  I remember my Audi Ceramic 6 pot weighting near to 9kg with everything inside them
                  • Julian Iversen
                    • Jul 2013
                    • 84
                    • Country: Denmark
                    #24
                    Yes, just the caliper with pistons
                      I found this: http://www.audizine.com/forum/showth...=1#post7500346
                      • Julian Iversen
                        • Jul 2013
                        • 84
                        • Country: Denmark
                        #26
                        Thats the dry empty weight. 6.5 was with pistons, brakeline and maybe a bit of fluid
                          • 4754
                          Has this thread died? Needs a bump.
                          • Wheeljack
                            • May 2005
                            • 219
                            Those 17Z/18Z weights seem low, even unloaded...
                            Here are some actual weights from parts I've measured...
                            17Z loaded caliper: 13.8 lbs. (6.27 kg)
                            18Z loaded caliper: 14.4 lbs. (6.54 kg)
                            996/Boxster S loaded caliper: 7.8 lbs. (3.54 kg)
                            345x30 D2 S8 rotor: 26.0 lbs. (11.81 kg)
                            323x30 D2 A8 rotor: 23.2 lbs. (10.55 kg)
                            HTH
                              Excellent, thanks
                              • GazzaG60
                                • 4133
                                im strugg;ing for scales.
                                what i do know is the pads are really heavy on the gt2. massive pads. gotta weigh neatrly as much as caliper
