The Brake Component Weight Thread
  • Rusty
    • 18953
    996s are light compared to 6 pots! Even with S8 discs, they'd be lighter overall than S5 & 6 pots. Just shows that it pays to define the problem...
    996s & 2 piece discs will be lighter still.
    • Wheeljack
      • May 2005
      • 219
      Totally agree. The 6 pots and 1 pc rotors can weigh 6+ kg more per side than 996 and 2 piece rotors. Looks aside, in most cases the 996 route is probably the better system solution. Some people just want the performance 'look' of the 6 pots.
        I also agree, IMHO the 429/430 big 4 pots with two piece rotor is the best all round compromise of cost / weight / performance
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          #34
          The brembos big reds are the mitsubishi Evo ones
          By the way, after installed my Ap's my big reds are available
          They are a very good setup with performance Friction two piece rotors and Carbotech XP8/10 brake pads for a fast road car with occasionally track days
          • Rusty
            • 18953
            Think I'm still heading towards 330x32 merc disc with 429/430. Cost effective, suitable upgrade on the 314s (more so in thermal mass) and will fit easily under 17s.
            • Rusty
              • 18953
              Size?
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #37
                Size?
                That's for me Andy?
                If yes, I can take some measures and weights easily because are off the car.
                These calipers has bigger pistons than the 429/430 gt3
                OEM rotors on Evo calipers are 320x32
                • Rusty
                  • 18953
                  Do let me know
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #39
                    Do let me know
                    I'll try to catch them ASAP from the garage then
                    • Rusty
                      • 18953
                      Be good to know the weight of the 996 429/430s too
                        • 12431
                        S2 standard front disc - 276 x 25 [7.0 Kg]
                        S2 standard front caliper - [4.2 Kg]
                        S2 standard front caliper carrier - [ Kg]
                        Updating an old thread here. So comparing stock weights to AP Racing Formula kit on the front:
                        Disc and Bell (330x28 disc) 6.9Kg
                        Carrier 0.795 Kg
                        Calipers (no pads) 2.4kg
                        so all in 10.095kg compared to Stock brakes with carrier assumed to be around 1kg it saves nearly 2Kg per corner on weight.
                          Nice one Greg. I should update this as I have a growing collection of calipers here
