Urs4 urs6 rear brake upgrade
  • Devious Delight
    • Aug 2015
    • 1
    Those that are locking up the rear brake, is that with the touareg brake upgrade?
    • RichLV
      • Mar 2015
      • 872
      • Country: Latvia
      So basically you just throw an adapter plate, bolt your standard calipers and strap on 310x22mm discs? Where the disc is from? A8/S8?
        D3 / Phaeton
        • RichLV
          • Mar 2015
          • 872
          • Country: Latvia
          How much for the plates?
          • diesel des
            • 3896
            #20
            Could these be modified to fit on an s2? I think this rear brake size would be perfect for my Urq s2 setup.
            • Thuppu
              • 4115
              More info about the UrS4/6 rear brake adapters.
              This is to use with stock calipers and 310x22mm discs:
              This is to fit Touareg/Cayenne Brembo rear calipers with 330x22mm discs:
              • RichLV
                • Mar 2015
                • 872
                • Country: Latvia
                #22
                My rear brakes recently have been refurbished, when they will start to die again, I'll get a set of brackets. What's electro coat btw?
                • Thuppu
                  • 4115
                  It's zinc coating made electrically https://en.wikipedia.org/wiki/Electrogalvanization
                  • RichLV
                    • Mar 2015
                    • 872
                    • Country: Latvia
                    #24
                    Electrolysis, cool. Are the brackets in limited quantity or available when I'm ready to purchase them? Shipment to Latvia?
                    • Thuppu
                      • 4115
                      Sometimes small stock, usually made on order.
                      Shipment to Latvia up to 2kg 21,20e, 5kg 24,30e.
                      • maiks
                        • Dec 2014
                        • 295
                        I have thuppu's rear brakes upgrade and I'm also very happy with them!
                        • Majorcina
                          • Jun 2013
                          • 1334
                          • Country: Montenegro
                          #27
                          I have Thoma's front and rear brembo adapters.Simple upgrade,plug and play.Strongly recomend it,and Thomas is great guy to work with
                          • orignalS60
                            • Mar 2015
                            • 792
                            • Home: Croatia Current: United States
                            #28
                            Thomas any developments on the e-brake cable solution for the brembo's in the rear?
                            • Thuppu
                              • 4115
                              Yes.
                              • popdemonic
                                • Dec 2007
                                • 1304
                                • Country: Thailand
                                #30
                                I'm waiting Thomas lol.it seems there's a bunch of demand here.
                                one of a few I5 from Asia.
