Urs4 urs6 rear brake upgrade
  • Urs4 urs6 rear brake upgrade
    I have a seized rear driver side caliper and need discs and pads. So it seems a good time to do an upgrade if such a thing exists? Anything out there. I'm willing to change both calipers if required.
    Cheers des
    Sent from my SM-G900F using Tapatalk
    Search for some of the rear brake products Thuppu is bringing (or has brought) to the market.
      Cheers pm sent.
        or have a look here: http://ultimot.de/
          My german isn't too good but this looks like a kit using stock calipers?
          http://ultimot.de/Komponente.php?id=BK102&TypWahl=015
          A bit expensive???
            Hello des,
            I got your PM, but I'll put the answer here. I can offer a adapter kit to use with UrS stock rear calipers and 310x22mm discs. Price is 35e/kit(bolts not included). This kit has been track proven and a lot of users have it already, and I havn't got any bad feedback.
            More info can be found here:
            http://www.s2forum.com/forum/showthread.php?t=66441
            ...and the sales thread:
            http://www.s2forum.com/forum/showthread.php?t=67887
            Then if you wan't get rid of the stock calipers, I have an kit coming for fitting Touareg rear Brembo calipers and 330x22mm discs on our cars. Of course there isn't any e-brake mechanism in this caliper, but the adapter has fitting point's for a custom e-brake solution. This havn't been tested yet, big test will be next summer on track.
              Ready for those brackets when you have them finished. I will happily beta test them.
              "Nulla tenaci invia est via"
                I can supply you a pair of them, shipping in a week if you wan't. There is two minor problems left with the fitting. One is that the lower caliper fitting is a really tight fit. Would propably bee needed to use a countersenk bolt and little machining on the caliper ear. Second issue is that you can't fit the caliper deeper in, the disc isn't in the middle of it, so would propably need to use a 4-5mm spacer behind the disc.
                  I would make the beta tester for the front brake adapters
                  Audi UrS4 20VT Precision 6262, VEMS, CatCams, SOLD
                  VW T4 TDI Multivan
                  pleasure by pressure...
                  If you are not breaking parts, you're not going fast enough...
                    That can be arranged.
                      UrS4/6 Touareg Brembo rear adapter kit
                        So I fitted the brackets and bigger disks with new textar pads. Big improvement! On a cold greasy road I can easily lock the rear wheels at 50mph with the handbrake! !
                        And it looks better too. Very happy.
                          Thanks Thomas! !
                            Glad you are happy with them.
                            Even that there is a great improvement in the braking force, I had zero problems with locking rears at track last summer. No lockups what so ever (not talking about the e-brake).
                            • #15
                              Thuppu UrS4/S6 rear brake upgrade is deffenitly worth to do.
                              It did it for my UrS4 and i can even lock rear wheels with handbrake 100kmh. I had to try.
                              Also this setup looks great, before the disc where so small thet they were bearly visible behind the wheels.
                              Before setup:
                              Audi UrS4 609hp/846Nm @ wheels
                              10.911@210, 1km 268km/h, 1mile 295km/h
                              FATS 2,30 sec
