This is one for those running 996/Boxster S calipers - 996421425/6, I'm interested to hear your feedback from running your 996 calipers.
I ask because I've never been happy with the pedal feel with my 996 calipers - sure they stop the car well and hold up fine to abuse on track, but the pedal feel I have always found soft & uninspiring and requiring a lot of pedal effort to stop quickly. I swapped to vacuum servo believing the hydro system to have been the main culprit, and that did help a little but it was not a significant improvement.
I've bled the car that many times I can't count, so today I went to town with a homemade brake line pressure gauge. I isolated the master cylinder with bleed hipples in all the line ports, bled through and the pedal was hard as rock, and using all that my stumpy legs could give me I could generate about 60-70bar peak pressure without servo assistance - this stacks up pretty well against my calculation for approx maximum line pressure:
25.4mm MC = 506mm2
Approx pedal effort ~ 800N
Pedal ratio ~ 4:1
So line pressure should be (800 * 4) /506 = 6.32n/mm2 = 63.2bar
So I knew the master cylinder is fine.
Next up, master cylinder and ABS unit isolated with bleed nipples, same story pedal hard as a rock and the same pressure reading from all 3 outlet ports on the ABS unit.
I connected the rear circuit first and bleed that through, expecting the little slider calipers to be the problem. I hit the pedal again, there was a faction of pedal travel this time, to be expected - but pedal still very firm. I put this down to wear on the slider pins causing the caliper to deflect slightly. Max pressure reading at the rear axle ~ 30-35bar which seems about right and indicates the pressure regulator is working.
Then I connected up the front lines up, one at a time and followed the same procedure. I was seeing full pressure from the master cylinder of 60bar but the brake pedal was soft as I had always found before.
I wondered if the discs were warped and bowl shaped so I removed the disc and pads an put a chunk of thick wall box section in between the pistons and tried again - still soft. I put it all back together and with the help of my glamorous assistant I was able to watch as she pumped the pedal. It looked like it was a combination of the pad compressing slightly and the caliper body itself flexing
So am I expecting too much? What are other peoples feedback on this set-up?
25.4mm MC = 506mm2
Pedal ratio ~ 4:1
and at least it dies compared to stock
