MAYBE a solution for handbrake with cayene 4pot rear caliper?
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    I was thinking what to do about my handbrake with cayene rears
    And it hit me,what about making a hydro handbrake? Puting cylinder and keeping the stock looking handbrake,and then make a "T" peace on left and right cayene caliper so handbrake can work without aditional caliper's
    It this posible?Or i am just dreaming
  • mike74
    • Apr 2014
    • 615
    Possible, probably but over here at least, illegal. We need a mechanical handbrake to pass the MOT
    • Majorcina
      • Jun 2013
      • 1334
      Here we only need them to work,its all legal
      • popdemonic
        • Dec 2007
        • 1304
        • Country: Thailand
        My froend has done on rear boxster but it seems the e brake can be working with only one side caliper.
        one of a few I5 from Asia.
        • LHD_Kid
          • May 2006
          • 3696
          Pretty sure that's not the case here now. What with all the e-brakes they had to do something.
          I'm sure a current tester can confirm though...
          • andy10v
            • 5996
            Not according to the MOT information;
            An electronic parking brake (EPB), although applied electronically, must be maintained in operation by direct mechanical means. This mechanism may be within the brake caliper or within the motor/gear assembly, so cannot be readily seen.
            Hydraulic parking brakes as a sole means of operation are not acceptable on vehicles first used on or after 1 January 1968. However, they may be used to assist the application or release of a mechanical brake.
            Sold ABY-stock
            • Majorcina
              • Jun 2013
              • 1334
              Can we skip the legal terms for a moment, i belive the is doable,just not sure will there be enouf presure for handbrake like this?
              • andy10v
                • 5996
                You can fit a hydraulic handbrake to operate the rear brake calipers.
                Does your car have a single brake line going back to a T to either caliper?
                Sold ABY-stock
                • Majorcina
                  • Jun 2013
                  • 1334
                  1 line per caliper,no T peaces.
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    try searching on some of the drifting forums, they all use hydraulic handbrakes (hydro)
                    • orignalS60
                      • Mar 2015
                      • 792
                      • Home: Croatia Current: United States
                      Hydraulic will work and is relatively easy to do but you guys will not pass MOT with it or in the US states that do a thorough inspection probably will not pass the car either. Check out Edigreg on the project pad.com and motorgeek. He did the hydro hand brake on his urs4 with boxster S 4 pot rear calipers. The same ones I'll be using. I also don't like the idea for a hydro hand brake for when parking on a steep hill or mountain because as you know if pressure bleeds off you can say bye to your vehicle.
                      • orignalS60
                        • Mar 2015
                        • 792
                        Also I think HAP with the green monster is using a hydraulic parking brake.
                        • V6quattro
                          • Sep 2008
                          • 949
                          I also use a hydraulic handbrake and it is legal here to
                          1360kg/600Whp Avant 0-200km/h 9sec
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            What's wrong with leaving the car in gear and use the parking brake at the same time?
                              TBH I hardly use my handbrake, I mostly just leave the car in gear as the brakes are normally pretty hot. But in the UK you need a mechanical handbrake to be road legal
