The Last Piece Of The Jigsaw
  • bilko0795
    • Feb 2011
    • 1883
    I recieved these today and they are the last things i need for my rear brake conversion. The complete package.
    Just got to decide which rear calipers to use ( Black or Red )
  • jsol
    • Jul 2011
    • 353
    • Country: Australia
    Awesome! What r these going on?
    • bilko0795
      • Feb 2011
      • 1883
      On my S2 coupe
      • dubmanted
        • Jun 2014
        • 312
        Whoa where and how much were the H/B calipers if you dont mind me asking? Im only after one for my coupé aswell
        • bilko0795
          • Feb 2011
          • 1883
          ÂŁ454 the pair delivered i was lucky to find these. as everywhere else were ÂŁ800 to ÂŁ850 a pair.
          • ColonialNomad
            • Feb 2015
            • 392
            • Home: United Kingdom Current: China
            A parts list would be really interesting. Would you be able to provide a brake down (cough) of what you bought?
            • bilko0795
              • Feb 2011
              • 1883
              1 handbrake adapters. ( Bambridge ) ÂŁ42.50
              2 Porsche rear calipers from a 996 turbo and a boxter 986 havn't decided which ones to use yet. ÂŁ162 for the 986 and i already had the 996 turbo ones pads were ÂŁ42.59
              3 Audi b6 S4 300mm rear disc's from EBC. ÂŁ122.02
              4 Handbrake cables from Audi S2 Avant. ÂŁ29.98
              5 Porsche Caliper adapters from VRS. ÂŁ152
              6 6 x M10 x 1.25 x 65 from TPS. ÂŁ10.98
              7 4 x M8 x 1.25 x 65 for the handbrake calipers from ebay. ÂŁ5.89
              8 4 x m10 x 1.25 x 20mm for brake caliper adapters. ÂŁ4.22
              9 A set of braided brake hoses from HEL for S2 coupe. ÂŁ119.80
              10 2 x double male brake nipples for the calipers ebay. ÂŁ 3.95
              11 A pair of handbrake calipers from ap Ap Racing. ÂŁ 477 60
              12 A set of Pagid rear brake pads. ÂŁ31.79
              13 2 x m6 x 1.0 bolts to hold the rear disc on the hub (optional) ÂŁ4.95
              • Rusty
                • 18953
                What are you pairing these with up front?
                You'll almost certainly need to adjust the brake bias!
                • Henkjan
                  • 1705
                  so you re-use the normal coupé brakehose with the nipple in the Porsche calipers?
                    I don't think they will be long enough at the back Ray
                    • mac2226
                      • Jun 2008
                      • 1289
                      He shouldn't need to if he's running 996 fronts as well like johnb has on his coupe I have Porsche Cayenne 6 pots up front instead of 996 turbo 4 pots mine stops very well it doesn't nose dive or lock back up As well as doing emergency stop with my mate in it
                      • bilko0795
                        • Feb 2011
                        • 1883
                        I have 996 turbo up front. I pm'd John and he told me that i don't have to adjust the bias as his set up works fine and i will be using the smaller caliper from the 986 boxster as he has.
                        • bilko0795
                          • Feb 2011
                          • 1883
                          No i will be using the Hel lines and the double male nipple in the caliper they are the smallest ones in the picky.
                          • bilko0795
                            • Feb 2011
                            • 1883
                            Alex do you mean the smaller of the lines will be to short ? I already have Hel up front so the middle pair of the set will be used if the other pair are to short.
                            • Rusty
                              • 18953
                              I have stock calipers with 314mm rears and it's too rear-biased.
                              That doesn't mean that your setup will be, as they're completely different but still, you're hugely upgrading the rear brakes, so just make sure you're careful, especially in the wet, which is where my brakes are too much.
                              My issues were mainly on track, which isn't where you'll use yours but also under emergency braking scenarios.
                              There's also the issue to getting heat in to the front pads (depending on what you use) but this will be different again on yours as the pads will be a similar size and mass.
                              Overall, not really much to take from all that but as long as you take the note of my words of caution, you'll be laughing.
