fitting pedal box to ur or s2
  • diesel des
    • 3896
    #31
    Got my obd one fitted. Seems good quality. A fair bit of work...
    Sent from my HTC Desire HD A9191 using Tapatalk 2
    • Jonnybravo
      • Aug 2008
      • 2051
      I would strongly advise you at least change the master cylinders. Just had another one play up and swapped the cylinder for a AP item.
      The later pedal boxes do appear to be a lot better than the early ones though, just a shame they failed at copying a proven master cylinder
      • diesel des
        • 3896
        #33
        What's up with the master cylinders?
        • Jonnybravo
          • Aug 2008
          • 2051
          They are very poor quality. Although their pedal boxes aren't great quality they physically work, it's the cylinders that are not reliable, inconsistant brake line pressure in some cases no pressure. It's always the same story with them and when you rely on your brakes so much it's just not acceptable to have such issues.
