RS2 uses the same master cylinder as the S2
Holy cow ive got brakes!
Aah, Lydden Hill, I used to go there as a kid to watch all sorts of motorracing there, sitting on the bank. Grew up not all that far away from Lydden Hill... Great circuit, really sinuous and twisty. McLaren were going to buy it a few years ago as a development track, but the local council refused them, the stupid morons.
RS2 has same master cylinder as S2 by the way. Sounds like you could do with another quick bleed if you're getting a bit of sponge - when you put it all back together did you bleed out the back brakes first?Ex S2 owner, now running around in an A4 Avant quattro...
McLaren now use Dunsfold Aerodrome to train the new owners of the SLR. Same place that Top Gear is filmed.
When bleeding brakes always start furthest away from the master cylinder, or in the case of an ABS equipped car start furthest away from the ABS pump and work towards the one closest. There are also ways TO and NOT TO bleed multipot calipers!1995 S2 Avant with some upgrades
Designun Limited....
Aerospace, Space and Motorsport Design Consultancy and hardware supply.Comment
@ lee, any more info on the do's and dont's? might be handy as there seems to be so many people on here doing vrake upgrades at the mo.
@danb, i live about 2 miles away from the circuit so its nice and handy. If you like Lydden, try Folembrey in France, its only about 90 mins away from calais and very similar to Lydden in its design, just a bit longer. The surface isnt great though.
Nice one
GavS2 Cabriolet.........
yes, i think too, this brake must be on each s2..i have had neraly the same, but 314x30 Audi A8 discs an the small rs2 calipers..ist awsome against the oem s2 brake..'94 (R)S2 Sedan
Engine:
81.4mm Forged Mahle Pistons, Pauter Rods, PKM Crankshaft V2, PKM Head V3 , PKM IM,CM Intercooler,Special Headbolts, SQ MAF,Samco Hoses, GT2Injectors, Dahlbäck Racing EM, KKK27 #9 Hotside, CM 76mm SS Exhaust, no cat
Chassis:
KW Competition, Porsche 933 Turbo Brake 322x32, 4 Caliper, Porsche GT3 Wheels 18"
Body:
RS2 Frontbumper, RS2 Rearbumper, RS2 Mirrors, RS2 MiddleTaillight, Black Hella Taillights, RS6 BixenonComment
