Can someone tell me what the distance centre to centre of the caliper bolt holes on standard front hubs please .. Cheers
Front s2 hubs
Tags: None
Well I think I want the A8l armoured a8 discs according to Wil at VRS .. They're 330 x 30 odd I think .?
Wanted to use my standard 16," Avus but gotta be 17" looking at every upgrade thread I can find ! It's the brackets I'm struggling with .. So 94mm x 145mm would be bolt hole spacing then I need ..Comment
I thought 429/430 fit under the 16"Avus?96 URS6 plus speck saloon
99 2.8 final edition CabrioletComment
Thanks Andy.
Further to this just a thought - tell me if I'm being thick - but most of the larger thicker discs ie R32 discs etc are 100 pcd so can't I just fit hubsentric adapter 112 to 100 then I can fit discs of choise and then obviously 17 " s3 avus or whatever over my 996 T calipers with a 100pcd adapter for the caliper .....?Comment
Um... R32 disc is 5X112 pdc. 30mm thick & 345mm diameter. Center bore is 65mm.
"Nulla tenaci invia est via"Comment
Yep what he said , suppose it would depend on hat height for it all to fit together..Last edited by Gazmitchell; 15 October 2015, 21:16.Comment
