Some Brake Upgrade for the S2
  • Ruhmic
    • Feb 2010
    • 44
    Hello,
    a few months ago somebody has asked me whether I am able here to do some information about my braking conversions that I have done. I will start with the last conversion that I made.
    The car from these conversion is the S2 Avant. For the S2 Coupe the conversion did also match.
    These parts used for the conversion:
    RS3 4-Pot Brake calipers with pads (New Version)
    RS3 370x32 Brake Discs (Centre hole machined)
    RS2 Brake Line
    Audi Original Bolts
    Bracket self designed and CNC machined from a friend.
    Mounted wheels on the car: Sportec Mono 10, 8,5x18 ET35
  • GazzaG60
    • 4133
    think there may already be a thread like this.
    heres mine though and sources and approx cost
    gt2 6 pot - ebay £300
    993 tt disc - ecp £120 each
    hel custom line 650mm 2 grommet (as per ebay s4 brembo lines they sell but longer and extra grommet) - £50
    custom bell and custom bracket - cant remember bout 300-400
    pads - ebay £20
    fits under 17" wheel
    • Ruhmic
      • Feb 2010
      • 44
      RS3 Brake Kit
      Here are some photos from the parts of the conversion.
      The discs are machined at the centre hole to fit at the S2 Hubs.
      The brackets are designed to Fit for the S2 conversion and for the A4 B5 with the disc from the TTRS
      • Ruhmic
        • Feb 2010
        • 44
        Mounted
        Here are some pictures from the mounted bracket to the car and Brake calipers
        • Ruhmic
          • Feb 2010
          • 44
          Mounted
          Some more pictures from the mounted parts.
          • Ruhmic
            • Feb 2010
            • 44
            Mounted
            Here some more pictures with mounted wheels
              Very nice
              Did you also do a R8 rear conversion with brembo handbrake caliper a few years ago?
              • Ruhmic
                • Feb 2010
                • 44
                R8 Brake conversion
                Thank´s Error
                Yes the R8 solution with the Audi Handbrake caliper was built from me.
                In the next weeks I will post more from conversions that we have done for the S2 or the Urquattro.
                • Ruhmic
                  • Feb 2010
                  • 44
                  Costs for the RS3 Brake conversion
                  For the interested people here some information about the price
                  The complete costs for the RS3 conversion was at 1350€
                  The parts where all new.
                  The most parts I have bought in Auctions at ebay.de
                  New Brake calipers with pads: 650€ in ebay
                  New Brake disc: 300€ in ebay
                  Brackets and disc machining: 300€
                  Bolts and RS2 Brake Lines: 100€ by the Audi dealer
                  When you get some used parts you can built it much cheaper then the 1350€
                  • Rusty
                    • 18953
                    Good work
                    Looks like a similar caliper to the Porsche Monoblocks. Looks like an interesting caliper to use to fit under 17s with something a little smaller in diameter.
                    • morgenlatte
                      • Jan 2013
                      • 101
                      • Country: Austria
                      i also have the TTRS calipers with 330mm discs under 17" wheels.. fits very nice (not on a s2 but possible with adapters)
                      1990 Audi 100 2.2 Turbo Quattro with VEMS, K24 2480, ported and milled 10v head
                      • GazzaG60
                        • 4133
                        nice, looks good
                        • diesel des
                          • 3896
                          Are those 2 part disks?
                            Yes kind of, the they are single piece but the hat is alloy, the rotor is suspended on spokes do they are "floating"
                            • diesel des
                              • 3896
                              Interesting setup. Anyone really push them to see how they get on with heat. Do they warp or stick it ok?
