I was referring to fig. 46-922 on page 46-13.
RS2 Handbrake Adjuster
Hand brake now adjusted superbly, once i had bought myself a decent bright torch i could see the adjusted as described and it was a simple as its supposed to be. Better that removing the prop-shaft, it took me all of about 2 mins on each adjuster once i had got the wheels off. Thanks very much all who gave good advice.
I need to do this as well but what I hope it at some point to make custom brackets and fit some brake calipers I have in addition to the rs2 ones that will only work as handbrake. I hope to connect the existing cables to them
Sent from my SM-P550 using Tapatalk
I find that hard to understand to have to adjust every 1000 miles, if the handbrake is adjusted properly then the shoes shouldn't wear as its only applied when the car is stopped so shouldn't induce any wear on the brake shoes at all. Unless its mal-adjusted or your moving with the handbrake applied.
Anyway I hope that mine lasts longer than 1000 miles, I will let you know of it is an issue.
