Bigger A8-type disc?
  • Bibby
    • Aug 2004
    • 1043
    Is there a disc available with the same dimensions as the 323x30 A8 disc, except with a larger diameter?
    acidtrax
  • s2driveruk
    • 12696
    Armoured A8/S8 uses a brembo sourced 345x30mm disc, about £130 a pair from proven products if i remember...
    HTH
    David
    1992 3b S2 Coupe
    • Bibby
      • Aug 2004
      • 1043
      I'll drop them an email, cheers.
      acidtrax
      • Corey
        Banned
        • Sep 2003
        • 2793
        Just under £100 from the stealer, each that is. Got a pair waiting to go on the S6 once we have bigger wheels. They will fit within a 17" but not with a 996 Carrera Monoblock, you would need the 6 pot from the GT3.
        Corey
        01636 822288
        • Bibby
          • Aug 2004
          • 1043
          Ah boo, never mind. Cheers for the info.
          acidtrax
            Question is why would you want larger than 323 with the Porsche Mono Blocks?
            With Ferodo Pads they're stonking.
            • audiman
              • 4827
              Brakes can never be big enough If i had some brackets made up for my hi-spec calipers i guess i could use those 345mm disks as they are the same width??
              Tom C - www.rcmr.co.uk
              Audi UR Quattro
              Audi 100 C3 2.0 5 cyl 115ps
              Audi B5 RS4 645ps 911nm
              • twoqu
                • Sep 2003
                • 3103
                Tom,
                Yep! They are identical except larger diameter.
                PM me if you are interested in a set.
                • audiman
                  • 4827
                  Mmmm, ok Robin I might just do that. I also have a little pressie left at my house for you Time for me to have a chat with Lee, so he can do his first bit of design for MRC Tuning!!!
                  Audi UR Quattro
                  • Lee
                    • 1512
                    Not the first for MRC Tom
                    Designun Limited....
                    • audiman
                      • 4827
                      This looks like a good viable option as the discs retail for about 71+VAT each from Audi!! Then i have the cost of the brackets, but that is only gonna be 20 quid i guess LMAO. I wish!! I have some spare box section from my crossmember, i could make my own
                      345x30 discs!! Should fill the 18" wheels up a bit better!
                      Audi UR Quattro
                      • martinjs
                        • 3205
                        They must weigh a ton though.
                        The 323's are heavy enough
                        • Corey
                          Banned
                          • Sep 2003
                          • 2793
                          Yeh! pretty heavy for a disc but the weight is offset (on the S6) by the removal of the stupidly heavy HP2 caliper setup as standard.
                          I like the thought though of a heavy one piece cast disc though, they make a very effective heat sink which helps to prevent the discs warping. So they can be abused more!!!
                          Corey
                          01636 822288
                          • Bibby
                            • Aug 2004
                            • 1043
                            I couldn't get over the weight difference between the 323mm disc and the split bell/rotor I took off my car!
                            acidtrax
                            • audiman
                              • 4827
                              Which was heavier?? The 314mm discs are damn heavy. Even Big red discs are heavy as hell.
                              Audi UR Quattro
