I am about to overhaul my recently acquired 996.351.425/6 calipers but before I do I will be fitting them to the car to ensure no further work will be required once overhauled and powder coated.
I am told there is a need to remove about 2mm from each pin with a grinder.
Looking at the calipers there appears to be a grub screw that is holding these pins in place.
Has anybody ever tried to move the pins rather than grinding them down?
orsum
S2 ABY Coupe
orsum
S2 ABY Coupe
