Caliper's mid way through, they need a quick wet 'n' dry then a good laquering but you get the idea.
996 to S6
And we also have the brackets back from the anodiser's then it is a question of just waiting for the braided lines to land and the wheels!!!
Then it is all systems go...Attached FilesCorey
01636 822288Comment
anyone got a CNC file for brackets to fit 996 calipers onto G60 equipped cars? essentially an RS2 bracket?Comment
Had a flash of inspiration this morning as I was laquering the caliper's, I have a wheel of the correct dimensions as the ones I am fitting, didn't think to use it while I was measuring up the brackets etc.
Tried it this morning and I can now confirm that this setup will fit within a 8x17 et40 wheel
all my measurements said it would but it is nice to see it in the flesh
Attached FilesCorey
01636 822288Comment
Uhhh like why bother - the RS2 caliper is 40 quid or thereabouts and allows the 996 calipers to bolt onto where G60s used to.Originally posted by spiralsmurfanyone got a CNC file for brackets to fit 996 calipers onto G60 equipped cars? essentially an RS2 bracket?Paul Nugent
It all depends on what disc's you want to use, anyway don't hijack my thread, start your own!!!
If you want to use the 314 disc (or the 323) use the RS2 brackets, if on the other hand you want something else then it is custom brackets all the way.
Corey
01636 822288Comment
I live in the US, is quid the same as GBP? The cheapest i've found them is $150/pair from VAGparts.
corey - sorry about the hijackComment
Porsche Paint/powder
Corey,
Did you paint, or did you powder coat. I am at the paint stage on my calipers.
Also, I lifted everything off an RS2, calipers, & brackets. Which size discs BIM that I have S8 18'sComment
By the way guys, S2central.net specifically...996 monos do not fit with RS2 brackets on the UrS4/6 because of the different hub offset.Comment
No one has said they do? Also if the urS4 has the UFO style caliper/ disc then it is another bracket design, also the hub diameter needs machining down to allow it to fit the disc.
The RS2 bracket also won't fit because on the HP2 caliper the bolt hole spacing is different.Corey
01636 822288Comment
Do you have measurements of HP2 caliper ? I mean distance between holes.Originally posted by CoreyNo one has said they do? Also if the urS4 has the UFO style caliper/ disc then it is another bracket design, also the hub diameter needs machining down to allow it to fit the disc.
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.comComment
