996 to S6
  • Corey
    Banned
    • Sep 2003
    • 2793
    Caliper's mid way through, they need a quick wet 'n' dry then a good laquering but you get the idea.
    Corey
    01636 822288
    • Corey
      Banned
      • Sep 2003
      • 2793
      And we also have the brackets back from the anodiser's then it is a question of just waiting for the braided lines to land and the wheels!!!
      Then it is all systems go...
      Corey
      01636 822288
        Fantastic work mate, credit and praise where it's due!
        • Dave cook
          • 312
          The CNC Master!
          • spiralsmurf
            • 21
            #20
            anyone got a CNC file for brackets to fit 996 calipers onto G60 equipped cars? essentially an RS2 bracket?
            • Corey
              Banned
              • Sep 2003
              • 2793
              Had a flash of inspiration this morning as I was laquering the caliper's, I have a wheel of the correct dimensions as the ones I am fitting, didn't think to use it while I was measuring up the brackets etc.
              Tried it this morning and I can now confirm that this setup will fit within a 8x17 et40 wheel
              all my measurements said it would but it is nice to see it in the flesh
              Corey
              01636 822288
                #22
                Uhhh like why bother - the RS2 caliper is 40 quid or thereabouts and allows the 996 calipers to bolt onto where G60s used to.
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  It all depends on what disc's you want to use, anyway don't hijack my thread, start your own!!!
                  If you want to use the 314 disc (or the 323) use the RS2 brackets, if on the other hand you want something else then it is custom brackets all the way.
                  Corey
                  01636 822288
                  • spiralsmurf
                    • 21
                    #24
                    I live in the US, is quid the same as GBP? The cheapest i've found them is $150/pair from VAGparts.
                    corey - sorry about the hijack
                    • Corey
                      Banned
                      • Sep 2003
                      • 2793
                      No worries, I will keep the hounds away for now.
                      Corey
                      01636 822288
                      • thefibreguy
                        • 87
                        #26
                        Porsche Paint/powder
                        Corey,
                        Did you paint, or did you powder coat. I am at the paint stage on my calipers.
                        Also, I lifted everything off an RS2, calipers, & brackets. Which size discs BIM that I have S8 18's
                        • spiralsmurf
                          • 21
                          #27
                          By the way guys, S2central.net specifically...996 monos do not fit with RS2 brackets on the UrS4/6 because of the different hub offset.
                          • Corey
                            Banned
                            • Sep 2003
                            • 2793
                            No one has said they do? Also if the urS4 has the UFO style caliper/ disc then it is another bracket design, also the hub diameter needs machining down to allow it to fit the disc.
                            The RS2 bracket also won't fit because on the HP2 caliper the bolt hole spacing is different.
                            Corey
                            01636 822288
                            • kwlw
                              • Sep 2004
                              • 1025
                              • Country: Lithuania
                              #29
                              Do you have measurements of HP2 caliper ? I mean distance between holes.
                              Sau
                              • Corey
                                Banned
                                • Sep 2003
                                • 2793
                                146mm between centres
                                Corey
                                01636 822288
