Audi UR Q brake master cylinder options....???
  • master6
    • Feb 2016
    • 27
    Video - Reverse Brake Bleed Method
    Adam,
    Have you ever tried reverse bleeding?
    Some on the BMW Forums, do not like it, as they think it pushes the old dirty fluid back into the system.
    And I agree, but if you have just changed to new fluid, it is okay to do.
    Works for me!
    Here is a YouTube Video of the reverse clutch bleed.
    But this principle, will work on brake bleeding also.
    Just start with the furthest wheel away from the M/C, and work forward.
    on USA cars, RR, LR, RF, LF.
    Link, Reverse Bleed
    Best,
    Jay
    Jay,
    My M6's
    https://goo.gl/photos/K3S9EkQ9veNrNDCf7
    • chezz
      • Apr 2007
      • 440
      Is the Servo new... What vehicle is it from? Probably a totally irrelevant point, but the clutch slave is feeding off the same brake reservoir now? If this has not been bled off as well...
        Sounds to me like the proportioning valve is bad.
        • speedfr38ky
          • Jul 2014
          • 76
          Jay, thanks for the advice will give it a try as part of elimination process for sure.
          • speedfr38ky
            • Jul 2014
            • 76
            [QUOTE=chezz;927648]Is the Servo new... What vehicle is it from? Probably a totally irrelevant point, but the clutch slave is feeding off the same brake reservoir now? If this has not been bled off
            No mate they arent. Seperate.
            • speedfr38ky
              • Jul 2014
              • 76
              Mate, Its a new one way check valve that was bought off ebay. Could be this but will have to check
                The symptoms are similar to what I remember when mine went, pedal goes down half way then feels wooden. Scary and unpredictable to drive.
                • speedfr38ky
                  • Jul 2014
                  • 76
                  Its worth me having it changed that's for sure...thanks.
