Hydraulic to vacuum servo conversion
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #46
    All that is for power steering, not for the brakes. Brakes can still use a vacuum servo and you can still have normal power steering. What's the problem with that?
    • Mark.se
      • Feb 2007
      • 131
      • Home: England Current: Sweden
      #47
      I did away with the brake 'bomb' when I put the AAN engine into my B4 80q, best thing I ever did.
      From this
      to this:
      2007 A4 2.0TS quattro (220)
      1995 AAN powered 80 quattro (MTM Stage 2, MTM hybrid turbo, MTM ecu, Forge DV, 034 Highoutput Coil Pack Conversion, Wagner Tuning EM, 3" turbo back SS exhaust system, race cat + other bits and pieces)
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #48
        perfect!!!
        which parts did you use? do you remember?
        was the strut brace able to be refitted without repositioning?
        • quattrofrank
          • Jul 2010
          • 127
          • Home: United States Current: Norway
          #49
          Originally posted by quattrostyle
          type 89 80's came without power steering, well some of them. How fast would you need one as my brother will change his for a power steered one.
          No rush, I will also check the orice for a new one, or is this in good shape?
          • Mark.se
            • Feb 2007
            • 131
            #50
            I just used other parts from an 80, re-routed the lines and hoses
            Sturt brace fitted without any problems
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #51
              that is very nice
              did you use an individual hose from the inlet manifold, or did you use a T joint?
              • rj scotty
                • May 2006
                • 2195
                #52
                Have you got a shot top down so we can see if ABY inlet will fit
                BUT I DON'T WANT A NEW CAR!
                1995 S2 Avant, Volcano Black
                • Mark.se
                  • Feb 2007
                  • 131
                  #53
                  Hang on a sec *exit stage left, grabs camera and keys*.....
                  • Mark.se
                    • Feb 2007
                    • 131
                    #54
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      #55
                      thanks for those!
                      • Mark.se
                        • Feb 2007
                        • 131
                        #56
                        Originally posted by A80Avant
                        thanks for those!
                        No problem, hope it helps
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          #57
                          i can also see some part number on the servo, and a word saying 'Lucas' but i think i have the correct part from Marc regarding that.
                          • rj scotty
                            • May 2006
                            • 2195
                            #58
                            This is looking uber viable now much cheaper than a new bomb if you play your cards right
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              #59
                              definitely and i wish i had done this ages ago, not 700+125+labour work+++++ for my brake servo to work...
                              im getting the last parts in for testing this week, and regardless of whether the brakes work, i am still getting the vaccum servo, the one way valve and any other bits necessary for a conversion...(just in case)
                              • Mark.se
                                • Feb 2007
                                • 131
                                #60
                                Any old servo will do it. B3 or B4
                                That's what I love about Audi's from this era, so many parts are interchangeable, or with a little bit of messing around join parts together from different models
