Just a thought regarding the whole boost/vacuum bit, can we not included a "vacuum accumulator" i.e a chamber with one way valves that will hold an amount of negative pressure so brakes will still work if you are on boost ?
Hydraulic to vacuum servo conversion
that is what the vaccum servo does already. It stores it not only for when you are on boost but for when the engine stalls as well. Something like the accumulator.Obviously it doesnt last long, which is why you cannot do left foot braking while on boost, but unless you do that regularly, there is no problemComment
sorted then, I don't do multitasking
BUT I DON'T WANT A NEW CAR!
1995 S2 Avant, Volcano Black
2003 VW T4 long nose X pack, (has become project)Comment
i have just got some info that the steering pump should also be replaced with one from a model that doesnt have the dual system as the one on our cars generates higher pressure and therefore by taping one exit it may reduce its longevity.
anyone has such experience?Comment
As my brakes are still not working, we are going to try and replace the master cylinder as well, as i have one new, although i doubt this would make a difference.
Can someone verify either:
1) Should a different power steering pump be used (A4 one) and if so, which part number
2) OR how does the s2/rs2 dual vane pump need to be modified in order to keep it, as it makes life easier that way?Comment
I run an ABY with Vacuum assist from the IM with a check valve, no probs, even a little left foot braking i no prob.
Fot details on fitting a 2.3 10v pump see the first post of my build thread i made a small adaptor plate from some 10mm aluminium plate, this is so that the 10v pump would fit the ABY bracket.
See also post #9 for single pumps that fit the aby bracket (some v6/v8 pumps from memory)
Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
"Difficult is worth doing"Comment
I have done this for a year.I'm now thinking to go for something bigger like dual diaphragm booster.one of a few I5 from Asia.Comment
dual diaphragm?
Is dual diaphragm booster the same as a tandembooster?
There are brakeboosters that work with both pressure AND vacuum called tandemboosters, the old 200T type 43 had one.
Regarding the problem with manufacturing brackets for A4 pump, there is also the possibility of fitting an electric pump instead, like the Opel Astra F pump i think has 100 bar but not 100% sure. Eliminates need for drivebelt.sigpic
80 quattro 1984..... S2 sedan 1994
Zermatt silver......... Brilliant blackComment
