996 351 425/426 Boxster s front brackets
  • mac2226
    • Jun 2008
    • 1289
    Can some one point me where I can get some of these please or can I use seat cupra r brackets I've read some where?
  • vonbeck
    • 2455
    yes you can use cupra brackets but if i remember correctly there is some machining involved from either one or both faces about 3/4mm and theyre fecking hard do a search as Im not 100% sure
    • kj6304
      • Nov 2016
      • 51
      • Home: Hong Kong Current: United States
      Apikol has good one for $239.00 for Audis. Make sure you order the right ones.
      Upgrade your Audi's brakes with our economical kit to bolt Porsche BoxsterS rear calipers over OEM Audi rotors for improved performance. Off-road use only!
      • mac2226
        • Jun 2008
        • 1289
        Thank for quick replys so just done some more searching and got my answer so 323mm s8 d2 discs are to be used with seat cupra r brackets machine down. Also it said there could be some rubbing from discs once they get hot any one who has had this on the 323mm discs and caliper setup?
        • orsum
          • May 2010
          • 1213
          • Home: United Kingdom Current: South Africa
          I have this setup with 321 discs, not fitted just yet but will be in the next 6 weeks.
          I will be interested on how your fitting goes.
          • mac2226
            • Jun 2008
            • 1289
            Will let you know mate
            • vonbeck
              • 2455
              I run this very same set up have for years with A8 disks with no problem what so ever
              • 90quattrocoupe
                • Nov 2003
                • 771
                I used RS2 carriers and did mine this way.
                These are the pieces needed for upgrading a coupe from brake system to use Porsche 996 brakes. This model caliper comes on two different cars, the Porsche 996 or the Boxster S. The 996 brakes are black and the Boxster S brakes are red. It seems that you can get these calipers in silver...
                Greg W.
                • mac2226
                  • Jun 2008
                  • 1289
                  Greg W.
                  Thanks Greg
