S6 rear calliper to hub bolts.
    • 4754
    Just rung Audi for 4 of these bolts (N 10038801 socket head bolt with hexagon socket head 10X1,25X50 ) and they want £11.50 each and i need 4
    Is there an alternative supply of these? Cheers Mark.
  • AndyP
    • 6049
    Search on EBay, they'll be a fraction of that price.
    https://www.ebay.co.uk/itm/231388117504
      • 4754
      Thanks Andy, sorry to be thick on this one,would that link be the right thread pitch and length of bolt.At times like this i wish i had trained as an engineer.
      • LHD_Kid
        • May 2006
        • 3697
        you put the exact size in your opening post ....
        • Thuppu
          • 4115
          M10 has 1.5mm pitch.
          • LHD_Kid
            • May 2006
            • 3697
            Unless its fine thread, in which case its 1.25......
            M10 standard thread is 1.50
            • _ShurikeN
              • Mar 2010
              • 733
              • Country: Russian Federation
              N10038801 bolt size is 10X1,25X50
              Rear brakes bolts are non-standard thread. Perhaps It's common for high-tensile bolts.
                10 x 1.25 x 50 - easy to find, standard fine pitch. Go to your local fastener supplier, or try ebay etc.
                You need minimum grade 10.9, 12.9 is stronger and might be easier to find.
                • LHD_Kid
                  • May 2006
                  • 3697
                  I'm not really sure why all the debate?
                  Click on Andy's link. Choose M10 x 50mm , pack size 4 and order...
                  They are 12.9 and standard fine thread... 1.25
                  £4.05
                    • Thuppu
                      • 4115
                      Yes well, then it is M10x1.25, but M10 is always 1.5mm.
                      • LHD_Kid
                        • May 2006
                        • 3697
                        I agree, but nobody said standard M10 (except you...)
                        The OP quoted 1.25 as pitch in his post and Andys linked to 1.25..............
                        I'll get my coat....
                          • 4754
                          Copied and pasted from 7 zap. Means fook all to me.
                          • Thuppu
                            • 4115
                            Sorry for messing up, looked little bit sloppy at the ebay link, thought they where basic M10 bolts... It clearly states M10x1.25, so my bad.
