Brake pad backing plate thingies
  • Bibby
    • Aug 2004
    • 1043
    On my current Textar pads in my 996 calipers there are shim plates glued to the back of the pads. They have metal sprung cups that sit inside the piston.
    Can these be re-used?
    Do they need to be glued to the pads and if so, what glue does one need to use?
    If I need new ones, does anyone have a part number?
    acidtrax
  • dan_b
    • Sep 2003
    • 3670
    They sound like the "Anti-squeal shims" that Brembos use to reduce brake squeak, and also act as a thermal layer to reduce heat input back in to the brake fluid.
    You can re-use them if they're not too bashed up. They don't need to be glued AFAIK, at least mine aren't. If you want replacements, VAG Parts sell them, they're not particuarly expensive. Some people (MikeS2 I think) actually run without them to no noticable ill effect.
    • Bibby
      • Aug 2004
      • 1043
      Cheers Dan.
      My Hawk HPS pads have just arrived, I'm a bit eager to fit them. The 996's with Textars aren't as good as the Alcon calipers with Mintex I had previous. Hopefully these should give an improvement.
      At £33 including delivery from Cambridge Motorsport they have to be worth a shot.
      acidtrax
      • Bibby
        • Aug 2004
        • 1043
        Damn, just discovered a split cv joint and I need to replace a wheel bearing. D'oh.
        acidtrax
        • dan_b
          • Sep 2003
          • 3670
          I've not heard of Hawk pads at all. I'm running Ferodo DS2500s and they're the best pad I've ever used. Well worth the £165 asking price
          Split CV boot - gutted
          • alg
            • Apr 2004
            • 1160
            IIRC porsche OEM use a sticky pad between plate and pad. I would check it out with a porsche specialist or search the posts here.
            Alastair
            RS2
            • dan_b
              • Sep 2003
              • 3670
              The squeal shim itself comes with a slightly sticky backing too it - you have to peel off a brown coated paper cover before you put it in the caliper, it's slightly tacky, but it's definitely not "gluey".
              Porsche apparently recommend to run the calipers dry - ie. no copaslip. I chucked a gallon of the stuff in
              • 90quattrocoupe
                • Nov 2003
                • 771
                I use the plate with Nickel anti seize on the back. Recommended from a Porsche tech. He said they never restick them to the back of the pads.
                Greg W.
                • Bibby
                  • Aug 2004
                  • 1043
                  Car is booked in Friday for the cv boot and wheel bearing. Will have to wait until they're done before fitting the pads.
                  Dan, http://www.hawkperformance.com/product_features.cfm
                  acidtrax
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    P/N 996.351.088.01. <£5 each from Porsche.
                    HTH
                    SS
                    • Beetie
                      • Oct 2003
                      • 1517
                      Copper grease < £free from work!
                      Was a '93 3B, Dont ask now tho......
                      • Bibby
                        • Aug 2004
                        • 1043
                        HTH
                        Cheers.
                        acidtrax
