My 996 monoblocks fitted too :-)
  • Jas11n
    • 5067
    Couldn't have said it better myself Karlos
    Really gave em some stick on the way home from work tonight, I don't believe in this "gently run them in" lark, never have done. I've always given a new set of discs and pads a good old hammer once fitted. Some may disagree, just like the old argument of how to run a new engine in, but it works for me.
    Good write up here
    Damn,,,,they don't half stop the car though,,,through the windscreen job.
    Jas
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • 90quattrocoupe
      • Nov 2003
      • 771
      Right all this concern about 323mm discs is getting me down again. I've ordered everything I need except discs. I note the RS2 big discs are actually 322mm (three two two) using the same carriers and a very similar caliper.
      I'm thinking of going with 323mm discs then having 1mm removed by a machine shop. Surely this will give me enough clearance with some heat in the discs. I don't intend to be tracking the car so they won't get a brutal punishment.
      I want to keep the brakes inside the 16" Avus rim for winter running - but I don't really want to go down to the 314mm disc if I can avoid it.
      Paul
      Paul,
      I bent my clips. Four track days. Changing out pads from street to track pads and back again. No problems with the brakes, no rattle, stops well, and no problem with the bent retaining pins. Besides, pins are cheap, removing 1 mm from the caliper by a proper machinist, is not cheap. Then you are always stuck with machined caliper
      Greg W.
      • Jas11n
        • 5067
        Update on the RS2 splash plate mystery. My brothers 95 Coupe has them fitted too Looks like Audi must have started to fit them towards the end of the production run
        Jas
