Autocheck With Radio Frequency Display?!
  • john881000
    • May 2004
    • 598
    trying out this weekend
    hi all
    got red plug already now
    going to check wiring place avaibility on back of my dash plug.......
    got test radio and display
    i will be the guinie pig............
    if ok will report back
    cheers
    john
    • kninio
      • Aug 2004
      • 641
      • Home: Lebanon Current: United States
      Cool , make picture too please that we could see better
      • valjo
        • 1110
        • Country: Latvia
        as you said there is red connector that goes from instrument cluster to the upper conector on back of radio (there is 3 connectors at radio). conector has 3 used pins, but you have to have radio with DATA output to have messages from radio ond AC display
        there is picture of radio conector, you have to connect to DATA,ena and CL pins
        ps. : if anyone is inetersted i have for sale gamma bose radio with cd control and ofcourse DATA output :mischeif:
        Audi Coupe S2 1993
        Audi V8 4.2 1993
        Audi cabrio 1998
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          How much for the radio, as I have one, but it is not the Bose version and therefore I suspect that it does not have the data output...I will check this lunch time.
          Also, could you post a pic of the rear of the unit please
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • valjo
            • 1110
            • Country: Latvia
            #20
            Cheers n
            Si
            hi!
            if your gamma look like (visual difference is only BOSE label and MODE switch) you have DATA output!
            at the moument i am unable to take picture but if you will need it remind me after week and i will take it for you!
            about price i send you pm
            Audi Coupe S2 1993
            Audi V8 4.2 1993
            Audi cabrio 1998
            • zlobo
              • 967
              this one migt be somthing for some one http://cgi.ebay.co.uk/ws/eBayISAPI.d...0363&rd=1&rd=1
              ABT C5 Lord Of The Rings
              2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
              2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
              2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
              kostic.nu
              • kninio
                • Aug 2004
                • 641
                #22
                I had one in my ex B4 V6 but with bigger display its thrown some where but i never find an audi fited with one like it or on ebay..... , its the same as the one valjo have but CD instead of casset
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  #23
                  Originally posted by john881000
                  brown/grey goes to V94.............central locking pump
                  OK, time for a dumb-ar$ed question then.....Why would I want my radio connected to my central locking pump?
                  I have just pulled my radio and I do not seem to have a red plug flapping around anywhere Just the afore mentioned brown/grey wire with the brown spade socket on the end which fits nicely on the male spade terminal on the back of the radio (which looks like an earth strap).
                  So, what should I do with this brown/grey wire and where the hell is my red connector and the leads that should be in it
                  Cheers n
                  Si
                  • valjo
                    • 1110
                    • Country: Latvia
                    #24
                    this one is old as .....
                    and it dont have DATA and RDS option
                    Audi Coupe S2 1993
                    Audi V8 4.2 1993
                    Audi cabrio 1998
                    • john881000
                      • May 2004
                      • 598
                      plugs
                      Hi all
                      some good news and bad
                      wire is connected to central locking pump with control unit for interior light switch off delay and anti alarm system
                      that is brown/grey.......as stated before from wiring diagram in front of me i thinks it for radio removal???........ if / and central locking/alarm off eg windows open car unlocked ........ if alarm has ****ion removal of radfion sends signal to control unit to alarm???
                      you wont hAve red plug if your car was destined to be here as prev mentioned................by others.......soi i been informed and from 1991-1992????
                      but looking on my early 90 quattro.. F reg.....which is at work i do have red plug...........and wires and they go to dash..colour of second wie different but allk three wires from red plug go there
                      i pulled my radio from my Audi 80 Avant tdi.......a concert radio.and plugged in ............nothing........................going to fetch an old an old Audi a4 gamma radio up from me dad and try it out tomorrow.will let you know
                      i changed my orignal dash for a S2 DASH..........my auto check screen was leaking on old screen
                      QUESTION.....till i find old dash...........there are green/whitish with tracks chip????.. 0n rev counter side part number 441893919 on MINE..on side of housing that comes off..are they all the same???
                      also at bottom of unit is a little lever with positions1-6................with what loooks like country letters....what they for??
                      need help fast getting wound up....................not knowing what to do
                      cheers
                      john
                      • Skull
                        • 3506
                        • Country: Slovenia
                        #26
                        this is kninio`s radio:
                        Audi Quattro WR
                        • john881000
                          • May 2004
                          • 598
                          Radio Questions
                          hi one last thing
                          HW MANY gamma radios did Audi make???
                          i using the one in A4/6/8 with red face
                          like in new Audi A4/A6/A6/A8
                          ON E4BAY look for item 110076668626
                          mines just like that one
                          cheers
                          john
                          • john881000
                            • May 2004
                            • 598
                            Just pulled my radio out car
                            Audi concert
                            my pins different at rear to diagram shown
                            i do hAve a data line feed but its in the top row of plugs(old Audis there where 3 small plugs............blue for cd player ----- yellow for options section----green for amp on rear speakers......) think i got last two correct
                            on newer Audis one big black plug
                            Tomorrow will have to try out thes pins in OPTION section
                            will lett you know of any devellopments
                            cheers
                            john
                            • zlobo
                              • 967
                              did't the bose ver have cd changer funktion?
                              kostic.nu
                              • zlobo
                                • 967
                                this one?
                                edit: culd not add pictures strange...
                                kostic.nu
