Window fuse?
  • Ski
    • 2591
    Window fuse?
    Hi guys,
    water went onto my elecy window button and it burned baby yeah!!!
    now no windows work (even from other buton on other door).
    Im trying to find the fuse, just cant find it in the fuse box...
    where the hell is it?
    ABY Coupe
  • marty
    • Nov 2003
    • 55
    think its in the dash under the steering wheel with the realays you have to take out the glove box thing above the pedels
    • Ski
      • 2591
      wow... seriously?
      hmm.. ok i take look under wheel.
      ABY Coupe
      • Dave cook
        • 312
        The windows don't have fuses they have circuit breakers i bet the problem is the the window control relay , its number ''285'' under the dash i think
        good luck
        • Ski
          • 2591
          ahh crap! was hoping it would be a simple fuse jobbie.
          I looked under the steering wheel and there are some references to electric window on the diagram. number 13, 5 and 6 point to electric window. but I cant find anything thats numbered under there just lots of relays here and there :/
          ABY Coupe
          • Dave cook
            • 312
            Heres the puppy
            • Dave cook
              • 312
              It should be the relay that is nearest to the drivers door,there are two relays it should be the top one if that makes sense
              • Ski
                • 2591
                cool!!! cant see it but will look harder once i have a replacement. Im guessing theres no way to visibly see if its blown ?
                ABY Coupe
                • Dave cook
                  • 312
                  I don't think so ,i'd would go to a beakers to get one, there about £140 new
                  Ski i might be able to source you one , i will double check the relay to see its the right one.
                  • Ski
                    • 2591
                    wtf how much ?? 140????
                    LOL, yes please have a look
                    ABY Coupe
                    • Dave cook
                      • 312
                      will do Ski
                      • Ski
                        • 2591
                        No longer need this dave. managed to sort one.
                        thanx for the help btw, hopefully once i put my door pannel back on it will stay on!
                        ABY Coupe
                        • Dave cook
                          • 312
                          no problem Ski , glad you got it sorted
                          • Ski
                            • 2591
                            not sorted yet, just found the correct parts
                            far from victory yet
                            ABY Coupe
                            • Ski
                              • 2591
                              top right relay in mine is labelled 363. Got replacement but no go
                              anyone know what the 363 relay is?
                              ABY Coupe
