ECU reading codes...
  • A80Avant
    • 10873
    • Country: Greece
    Hey,
    i have a question.I asked someone in charge for the vag-com program and cables about my problem(i cannot read the engine fault codes,but i can read everything else),and he said that if my car has 3 plugs(the third used for blinking out the codes),then this is how it was made in the early years.I can read the engine with a led and blinking,and i can read everything else with my VWtool or vag-com software.
    is that true?do you have 3 plugs or 2 on your cars?
    i didnt thinktha what he said sounded really professional,but i think i will try blinking out the codes just to see if there something coming out from the ecu...
    cheers
    vasilis
    Here's the link to the Blinks.. Really easy to do once you've sussed it.
    Linky To Blinky
    • A80Avant
      • 10873
      • Country: Greece
      thanks,
      but by the way,could what he said be true?does it have any logic to it?
      cheers Vasilis
      • BRY
        • 3755
        You can read the fault codes with both Vagcom and the led.
        We have three plugs on our S2s, last itme I looked!
        • A80Avant
          • 10873
          • Country: Greece
          i know i know!thats what i thought!!
          but is it possible that if vag-com cannot read the engine fault codes,that a led could??
          it sounds strange!!!
          • WabTheKing
            • May 2004
            • 2567
            my mate tryed plugging vagcom in the other da on his 3b s2, nout! tryed the led thing nout! whats causing this?, did a contiunity test on the wires back to the ecu all ok?
            (he did the test not me, just rang me up to see if i had an idea what could be wrong)
            • A80Avant
              • 10873
              • Country: Greece
              how do you do a continuity test from the plugs to the ECU??
              • WabTheKing
                • May 2004
                • 2567
                like i said he tested it not me
                • Nuvo
                  • Nov 2003
                  • 3826
                  You can use a DVM set to measure the resistance between the respective pins at each plug end.
                  Nuvo
                  • Welleh
                    • Aug 2005
                    • 106
                    done it with a fluke multimeter, just use buzzer test and bob's your uncle! its quite weird really, the wires arnt shorted, theres +12.3v across the black plug and theres +12.3v on the single pin from the blue plug to gnd! think that sounds about right, but the led just stays on when i try and trigger it with the jumper, no flashes or anything, and vagcom cant even find it!
                    • Welleh
                      • Aug 2005
                      • 106
                      anyone got any idea what so ever?
                      • mcandmar
                        • Apr 2004
                        • 5118
                        Check the Fuse, i blew one of mine before which took me a while to figure out, on a 7A there is a large red holder in the fuse box with two fuses in it, one is for the ECU and the other is for the diag connections. I would guess an S2 is the same...
                        Mark.
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                        • Welleh
                          • Aug 2005
                          • 106
                          the fuse is fine!, checked that and replaced them all before anything else! any other ideas?
