You do need an ABY/AAN/ADU valve cover, maybe coilpack cover if you really want it but it's not necessary to have it...
Options for 3b ignition
www.MRCTuning.com
info@MRCTuning.com
Workshop Directions -
Received the rs2 ECU and the wireloom (
didnt know there where so much connections) , thanks to Tjalling (TDHAA). The valve cover is on its way from Germany.
I was wondering if I could still use the normall 3b MAF (ofcourse I will not put in near the airbox), I thought that the range of the rs2 MAF is a bit wider but I dont know if this will effect the performance.
Some can tell me more?
thanks,
ErikGetting everything sorted out for my 5++ hp project
Are both of these mentioned coilpack upgrades (I assume for the 3B engine) needed for the GT 2871 turbo?
Are the coils of the 1.8T coilpack conversion "in cilinder"* (without cable) or are the coils placed somewhere else (with cable) (ofcourse they are both distributor less, 5 coilpack)
What kind of cost are involved (labour and parts) for both to get the job done properly?
* I don't know the correct word for itComment
