All of a sudden the electric windows on my S2 avant have decided not to work.
They were prefectly allright, but not having driven the car for a few days, they have stopped working.
I've looked in the fusebox, but can't find an appropriate fuse for these. Is there one??.
Any suggestions of where to look for a fault.
On another gremlin,
My main beam headlights don't work. They will on the flash, when you pull the stalk. But not when you want main beam. Again any thoughts gratefully received.
Also, ( I know, lot's of questions ). My rear fog light won't work. Checked the bulb, it's ok, and have put my multimeter across the wiring and seem to get 10/12 volts, but no light. Any clues where to look???.
Thank's in advance.
Trystan.
On another gremlin,
Thank's in advance.
Trystan.
. if possible take a meter and messure if you get any respons when opperating the switches then it could be a busted window el motor, or you cuold just have a bad wire somewhere..
