I have a non-functioning temp gauge in a 91 3B coupe.
I've had the MFTS out and tried grounding pin 1 to see if the gauge goes full scale, and it doesn't. So I've now got the clocks out to try and test the wiring between clocks and sender, but pin 1 on the MFTS has a Brown and Blue wire for the temp gauge. I cannot find a Brown and blue wire at the clock end, does it change colour before it gets to the clocks? Also has anybody got a wiring diagram or a test for the gauge once out of the car.
