Confused!!!!!
  • terrybullwon
    • Mar 2006
    • 8782
    so, is there any solution? i will look closer into the matter, have a little free time to day.
    Chef
    • ericd
      • Nov 2003
      • 1240
      check bulbs and post results, H4's have a 3 prong connection and H1 a single connection.
      • Fat Audi 80
        • 10547
        Originally posted by Jas11n
        Did you fit the ellipsoids Steve ? I meant the old headlights that came as standard with your car should have lit both the dipped and the main. I know your ellipsoids didn't do that after they were fitted, Marks were the same after he fitted his.
        As once said, Assumptions are the mother of all **** ups...
        So here goes.
        My car is 1993 ABY, but was pre mature and did not have time to develop Elipsoidal headlights or Avus rims.
        The previous owner retrofitted the elipsoidal lights and I then fitted HID's. When I fitted the HID's I blew a ballast as the dipped would alternate with Main beam UNLESS you held the stalk back a la "FU Flash". This was rectified via the MartinJS lighting stalk wiring mod and everything is now rosy in the HID garden.
        I am ASSUMING that up until I changed the wiring that the main beam / dipped beam alternation was a factory feature. It may not have been
        I am now going retire from this thread and
        The Perfectionist
          Well with your birthday today, your old enough to retire!!!
          • terrybullwon
            • Mar 2006
            • 8782
            right i rang the guy i brought the car off and from what he said it sounds like he wired it so the power of full beam will all go to the inner lights is this a good idea? aparently all i have to do is swap a wire back WHY
            Chef
            • mcandmar
              • Apr 2004
              • 5118
              All thats going to do is half your lighting power
              First thing to do is pull the bulb out and make sure it is a 55w bulb, and also check the H4 is a 55/60w bulb. Some people like to stick 100w bulbs in there and wonder why the wiring loom fries. Should just be a simple matter of re-connecting the wires onto the back of the H4 bulb for full beam then. Can you snap a pic of the back side so we can see what he has done, is there a wire disconnected?
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • terrybullwon
                • Mar 2006
                • 8782
                Cant do electrics my weakest area
                but heres some pics, its H4 because of the 3prong main light
                Chef
