so, is there any solution? i will look closer into the matter, have a little free time to day.
Confused!!!!!
As once said, Assumptions are the mother of all **** ups...Originally posted by Jas11nDid you fit the ellipsoids Steve ? I meant the old headlights that came as standard with your car should have lit both the dipped and the main. I know your ellipsoids didn't do that after they were fitted, Marks were the same after he fitted his.
So here goes.
My car is 1993 ABY, but was pre mature and did not have time to develop Elipsoidal headlights or Avus rims.
The previous owner retrofitted the elipsoidal lights and I then fitted HID's. When I fitted the HID's I blew a ballast as the dipped would alternate with Main beam UNLESS you held the stalk back a la "FU Flash". This was rectified via the MartinJS lighting stalk wiring mod and everything is now rosy in the HID garden.
I am ASSUMING that up until I changed the wiring that the main beam / dipped beam alternation was a factory feature. It may not have been
I am now going retire from this thread and
The Perfectionist
right i rang the guy i brought the car off and from what he said it sounds like he wired it so the power of full beam will all go to the inner lights
is this a good idea? aparently all i have to do is swap a wire back
WHY
ChefComment
All thats going to do is half your lighting power
First thing to do is pull the bulb out and make sure it is a 55w bulb, and also check the H4 is a 55/60w bulb. Some people like to stick 100w bulbs in there and wonder why the wiring loom fries. Should just be a simple matter of re-connecting the wires onto the back of the H4 bulb for full beam then. Can you snap a pic of the back side so we can see what he has done, is there a wire disconnected?
Originally posted by terrybullwonright i rang the guy i brought the car off and from what he said it sounds like he wired it so the power of full beam will all go to the inner lights
WHY
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Cant do electrics my weakest area
but heres some pics, its H4 because of the 3prong main light
ChefComment
