I would like to install the cruise control and the bord computer in my car, but to do that i need to enable them in my ecu trought vag-com. Anyone knows what codes must be inserted to enable this 2 options?
hmm i didnt mention for what engine that is. it is for my audi 80 1.9 tdi year 95. The cruise control is completly electric and that is why it should be enabled.
i have an aby wiring loom, and the wires are different compared to the one you have in the pic. i guess i will need the loom only for the connectors
The cruise control and onboard computer have there own wiring loom, not apart of the engine loom at all. They both plug into the engine loom at some point, cruise control only does that to get a vehicle speed signal, and the computer to get fueling rate info from the ECU. The cruise control system would work in any car as long as you give it a speed signal.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
